How to map string choice field to integer choice field using transform source script ?
05-04-2020 05:40 AM
Hi All ,
I am having a string choice field on import set table (table a)and i want to map the field to the target table's (table b) integer choice field.For Eg if in the import set table the status is disposed then on the target table the value will be mapped as retired. If anyone knows please help me out.
Dinesh Kumar G
05-05-2020 12:32 AM
Hi Dinesh,
Is there any update on this? Did this question get resolved or you need some more assistance.
06-01-2020 10:55 PM
Is this question resolved or you need some more assistance?
if my answer helped you, kindly mark it as ✅ Correct & 👍Helpful so that it does not appear in unanswered list & close the thread.
07-23-2020 11:13 PM
Hi Dinesh,
Hope you are doing good.
Let me know if that answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed.
