How to move schedule entries from one instance to another
Pihu1
Hi Community,
I have created new holiday schedule entries for existing schedules. I need help in moving schedule entries from one instance to another. I see 'Add to Update set ' related link in the schedule entries form Can I use that to manually add schedule entries  to current update set ?
Thanks in advance.
Pihu
P-Rudenko-SN
Hello, I'd suggest exporting the record to XML on the source instance, and then do the import on the target one. Make sure all related records (if any) are exported/imported as well.
Pihu1
Thank you! both for the replies.
