How to properly prioritze Problem records
Mitch Moran
Greetings,
We are looking for some guidance on how to best prioritize Problem records. Currently, when a new problem record is created, we just set it to a priority 4 and we would like to leverage the other options that best represent the priority of the problem. Any guidance or suggestions would be much appreciated.
Thank you!
AndersBGS
Hi @Mitch Moran ,
OOTB the problems will be created with similar priority as incidents… I would recommend you to look from a business perspective, to investigate what makes a problem high priority and what makes it low priority.
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
