How to query servicenow tickets using its API (powershell)
Matt Campbell1
Hello, I'm playing around with the SNOW API.
I'm trying to figure a method to query for task numbers from this table sc_task.
Hoping to get some help with this.
Currently on Jakarta for SNOW
$uri = "https://xxxxxxx.service-now.com/api/now/table/sc_task?
This my URL i'm using but i'm not sure what to add at the end of this URI to query a specific task number.
Matt
Ok..Do thhis
https://xxxxxxx.service-now.com/api/now/table/sc_task?sysparm_query=number=<Task Number>
The task number should be in format TASK0001231
For ex, I used
https://xxxxxxx.service-now.com/api/now/table/sc_task?sysparm_query=number=TASK0000001
9 REPLIES 9
Getting further, seems our proxy is blocking something causing the output to be wonky.
But i'll play around with it more.
Having %D seems to come back with a null results.
I tried running like this
https://xxxxxxx.service-now.com/service-now.com/api/now/table/sc_task?sysparm_query=number'0065475'"
but it was querying massive amounts of data(I stopped it), I think it was getting all the tickets within our SNOW system.
Guessing I did something wrong.  Maybe this type of query isn't available in Jakarta ?
Ok..Do thhis
For ex, I used
Genius! I had single quotes around the task which broke it.
Thanks for the help! I may have more question but i'll create a new thread for that.
sachin_namjoshi
Mega Patron
You can always use OOB REST API explorer which is inbuild and provides code examples for powershell too.
