How to restrict past date selection in due date field in problem task
Gopal14
Hi Team,
I want to restrict past date selection in due date field in problem task and Change task tables.
I have tried directly in UI Policy, it is working but in form it is showing error, if selected date has passed past date.
Apart from that how can i do this
16 REPLIES 16
Ankur Bawiskar
@Gopal14
UI policy is easiest with no/less script
Another way is to use onChange client script on that field
    g_form.hideFieldMsg('due_date');
    if (newValue != oldValue) {
        var RightNow = new Date().getTime();
        var end = new Date(g_form.getValue('due_date')).getTime();
        if (end < RightNow) {
            g_form.clearValue('due_date');
            g_form.showFieldMsg('due_date', 'The Due Date cannot be in the past. Please select a future date', 'error', true);
@Ankur Bawiskar
I have used same script it is working last week, now what happening is for problem_task when we select type as "Root Cause Analysis" it is not working. If we select type as "general" some times it is working, sometimes it is not working.
For change_task it is not working at all.
Apart from that I have observed other point as well, I have selected date as today date in due date it is working, I have changed the date to 08/02/2026 this date also it is accepting means it is not throwing any error message.
@Gopal14
so what debugging did you do if it's not working?
Ankur Bawiskar
@Gopal14
Your UI policy should be like this
@Ankur Bawiskar
I have tried using UI Policy, but what is happening is I have given today date in due date, it is accepting.
If I verify tomorrow, field value is cleared, it is showing error message, not able update the state of that particular record.
users are facing this issue
