How to restrict past date selection in due date field in problem task
02-03-2026 08:14 AM
Hi Team,
I want to restrict past date selection in due date field in problem task and Change task tables.
I have tried directly in UI Policy, it is working but in form it is showing error, if selected date has passed past date.
Apart from that how can i do this
02-03-2026 10:35 PM
so you don't want users to select today? Only tomorrow should be allowed?
what if current time is 12.05pm and if they select same date today but time as 12.10pm?
Is that allowed?
02-03-2026 10:40 PM
I want to select today then it needs to accept,
if I select past days then it should show error message.
02-03-2026 10:46 PM
Example:
In Due date I have selected date as 04/02/2026, it is accepted and it worked fine.
If I checks the same record tomorrow, due date value is showing as empty, because we are selecting clear value.
I don't want to clear the value
02-03-2026 11:09 PM
why not to clear if it's invalid?
If you don't want to clear then you can show error message near field
Is that not stopping user from saving an invalid date?
02-03-2026 11:57 PM
No it is not stopping, user is able to save that record after entering past date
below is example, I have add date as 1/2/2026, it show's error message, but it saves the record. below is the screenshot
