How to restrict past date selection in due date field in problem task
Gopal14
Hi Team,
I want to restrict past date selection in due date field in problem task and Change task tables.
I have tried directly in UI Policy, it is working but in form it is showing error, if selected date has passed past date.
Apart from that how can i do this
16 REPLIES 16
@Gopal14
why you don't want to clear?
I recommend clear since validation fails.
This ensures user doesn't save with wrong data.
Deėpak Sharma
Hi @Gopal14
Try this onchange client script:
Type: onChange
Table: Problem Task [problem_task]
Field Name: Due date [due_date]
    // 1. Get the current date (Browser time) and zero out the time component
    var today = new Date();
    today.setHours(0, 0, 0, 0);
    // 2. Convert the ServiceNow date format to a JS Date object
    // g_user_date_format is a system variable that ensures it works with your user's format preference
    var inputDateNum = getDateFromFormat(newValue, g_user_date_format);
    var inputDate = new Date(inputDateNum);
    inputDate.setHours(0, 0, 0, 0);
    // 3. Compare: If Input is strictly less than Today, it is in the past.
    // (If it is Equal to Today, this condition is false, so it allows it.)
    if (inputDate < today) {
        g_form.addErrorMessage('Due date cannot be in the past. Please select Today or a future date.');
        g_form.clearValue('due_date'); // Optional: Clear the invalid entry
If you don't want to maintain a script, you can use a UI Policy.
Table
Short Description: Validate Due Date not in Past
Conditions:
  • Due date | before | Today
    Run scripts
    : Checked.
    Execute if true:
function onCondition() {
    g_form.addErrorMessage('Past dates are not allowed.');
Happy to help! ‌‌
To help others in the community find this solution, kindly mark this response as the Correct Answer ‌‌ and Helpful‌‌.
Warm Regards,
Deepak Sharma
Community Rising Star 2025
