How to select multiple values in reference field at a time on form not in catalog item
Krishna92
Greetings of the day!!
I have field over my form. That is a reference field and filed type is list.Now the requirement is user should be able to select multiple values over that field at a time. Please suggest me some better ways to implement it.
Sajilal
Hi Krishna,
We had a client ask this as well, But in the list field also, the users can type the name one after another and that works like a multiple selection in one go, you can go ahead with this workaround.
Hope this helps!
Please Mark as ✅ Correct if this solves your issue and also mark ???? Helpful if it helps resolve your problem.
Saji
Krishna92
Hi Sajilal,
Thank you so much for your response
Krishna
Hi Krishna,
If your issue is resolved, request you to mark the answer as correct and helpful so that others can benefit in the Future.
Saji
