How to send Glide Records after quering database from Script Include in JSON format
G Sai Vamshi
Giga Guru
I have a requirement to Glide a table with specific conditions and result of that query ie records of that table should be returned in JSON Format.
Really appreciate that..I was able to crack the code till the same point. but where i am facing the difficulty is I need to push whole user record instead of two fields in an object and I need to get those user record values in the client side.
Hi @G Sai Vamshi what do you mean whole record? you want all the fields? then you need to push all the fields like below
userInform.field1= gr.getValue("field1");
userInform.field2= gr.getValue("field2");
userInform.field3= gr.getValue("field3");
so on
and finaly push all records
userData.push(userInform);
and in client script you need to parse the answer like below
var result = JSON.parse(answer); // using glideajax
Please provide your use case in detail to assist further.
Harish
Hi @G Sai Vamshi another way to get all fields is like this but consider performance issue here, do you really want to send all fields?
script:
gr.addActiveQuery();// Some appropriate filter here for better performance
var results = [];
while (gr.next()) {
var fields = gr.getFields();
result = {};
for (i = 0; i < fields.size(); i++) {
field = fields.get(i).getName();
result[field] = gr.getValue(field);
results.push(result);
var result= JSON.stringify(results);
gs.info(result);
Harish
