How to set delay in scheduled job for every run?
rkreddy
Giga Expert
I am using a scheduled job in which I am getting the records from a table and performing action on every record in while loop. Now I want to set some delay for every iteration in while loop, how to achieve it?
var csa = new GlideRecord('cmdb_ci_cloud_service_account');
csa.addEncodedQuery('datacenter_type!=null');
csa.query();
while(csa.next()){
var scheduleConfig = new global.CloudDiscoveryScheduleConfig();
var accountSysId = csa.sys_id + '';
var result = {};
try {
	result = scheduleConfig.discoverDatacenters(accountSysId);
} catch(err) {
	result.error = err;
we do nothing in that while as it will just iterate for 10 seconds
That's how the delay would be generated
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
Ankur Bawiskar
gs.sleep() is not recommended and won't work in scoped app
use this to give some 10 seconds delay in while loop
csa.query();
while(csa.next()){
	// wait for 10 seconds
	var seconds = parseInt(10, 10) * 1000;
	var start = parseInt(new Date().getTime()) + seconds;
	while(start>parseInt(new Date().getTime())){
		// do nothing
	var result = {};
	try {
	} catch(err) {
		result.error = err;
Hi @Ankur Bawiskar ,
Thank you. Could you please explain a little bit about using the below lines in the script. Don't we do anything in this while loop?
		// do nothing
Thank you. Will use this.
