How to set RITM state Work in Progress in flow designer once request is approved.
Challasunil
RITM Screenshot
Flow designer screenshot
2 ACCEPTED SOLUTIONS
Raghav Sharma24
Giga Patron
Did you use "update record" activity? in update record activity , you can select record as RITM from right panel and set the sate to "WIP" after the approval is done.
Mohit Kaushik
Hi @Challasunil,
you can add a new action step in Flow designer after your If approved step. You can use 'update record' action and there you can select your RITM for which approval is sent and update the state to Work in Progress.
Raghav Sharma24
Giga Patron
Mohit Kaushik
Hi @Challasunil,
Challasunil
Thank you @Raghav Sharma24 @Mohit Kaushik  🙂
