How to skip SSL in REST V2
Sivabalan1
In ServiceNow integration, how can I skip the SSL verification on RESTMessageV2?
var rm = new sn_ws.RESTMessageV2();
rm.setHttpMethod('post');
rm.setBasicAuth(userName,password);
rm.setEndpoint(url);
var response = rm.execute();
anything I missed to set in the rest message attribute?
Omkar Mone
Hi Siva,
You can set the following property to false, this will cause the HTTPClient to not make the hostname verification against the ssl certificate provided.
"com.glide.communications.httpclient.verify_hostname"   to false
Hope it will solve your issue.
Omkar Mone
2020 Community MVP
9 REPLIES 9
Type sys_properties.LIST in the application navigator and search for *com.glide.communications.httpclient.verify_hostname in the Name column of that table.
Let me know if that helps.
Omkar Mone
Sivabalan1
Thanks Omkar, it works.
You're welcome 🙂
Asrar
Kilo Explorer
when I add "com.glide.communications.httpclient.verify_hostname" property I get duplication error.
java.sql.BatchUpdateException: (conn=5595) Duplicate entry 'com.glide.communications.httpclient.verify_hostname' for key 'name'
but I can't see any property set with name "com.glide.communications.httpclient.verify_hostname"
