How to submit multiple RITMs from a single Request using Flow Designer ?
Satanik1
Giga Guru
Hello Experts,
I have a requirement where I have to create multiple requested items using using flow designer and all of them are having different variables. I am able to do the same by using Submit Catalog Item Request spoke. But the problem is, they all are having different requests.
What do I have to do in Flow designer, so that they all are created under same request ticket? I know that Order guide can do this. But is there a way to use it from Flow designer ?
Thanks in advance
Satanik
Yousaf
Hi Satanik,
Please refer to the link.
Looking to create 5 RITMs from one Catalog Item Request
Mark correct or Helpful if it helps.
Hi Yousaf,
Thanks for the reference. Just one thing. While I am going to try this on my pdi, but in the trigger I already have a condition stating that the flow should trigger when any new user is created.
Now for this case, I need to write the condition in Action with a if logic. But this may be a little vulnerable at times. Any suggestion ?
Satanik.
