How to translate confirm message from client script?
Hi Experts,
We have a requirement to translate a confirm message from client script.
confirm("You confirm that all information being submitted is accurate. If you are unsure select Cancel to return to editing, otherwise select OK.")
I tried below way and its not working
getMessage(("update personal information message", function(msg){
confirm(msg);}
Any one come across this translation? Please suggest.
Antony
Below setup for example, results correctly in Dutch in "Hallo", instead of English "Hello".
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
11 REPLIES 11
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Shivani Singh1
Hi Antony,
Just add <Your message> in "Message" field in client script also, then it will work fine with
confirm(getMessage("<Your message>"));
Please mark helpful if it solves the purpose
