how to trigger a script include from background script
Kongaleti Navee
I have faced one interview question recently that create a script include with two functions f1 and f2 in which you have to find difference between created on and resolved fields .if you call function 2 in the background script and run then the difference have to come as result .
can anyone please explain how to trigger a script include from background script and in which situation you have to use glide record object in background script to trigger the script include
AniketC85155510
Hello @Kongaleti Navee
Is there any update on my response? if my response was helpful in addressing your query or If it assisted you in resolving your issue, kindly consider marking it as helpful, accepting the solution, and closing the thread. Doing so will not only acknowledge the assistance provided but also benefit future readers who might encounter a similar problem.
Thank you! 😁
Aniket.
