how work with Cascade Variables in order guide
nagaraj3
with an example
Sanjay Bagri1
Hi nagaraj Go through these below links it will help you . https://www.google.co.in/url?sa=t&source=web&rct=j&url=https://docs.servicenow.com/bundle/london-it-service-management/page/product/service-catalog-management/concept/c_CascadeTheOrderGuideVariables.html&ved=2ahUKEwiC87CqoKfeAhXXfn0KHc_iAxMQFjABegQICxAE&usg=AOvVaw3zHi9xub8n8hOTO2dU7tD8
Sanjay Bagri1
different catalog item by pulling from initial form. Cascading allows values entered for variables in the initial order form to be passed to the equivalent variables in the ordered catalog items. For example, a variable on the initial order form prompts the customer to enter a delivery location value. If you enable cascading, the value for this variable then populates delivery location fields on each of the ordered items. It works like- select the Cascade variables check box when creating the order guide. Then, create variables on the catalog items that match the names of the corresponding variables in the order guide. When a customer places an order, the variables on the ordered items inherit the values of the identically named variables in the order guide. I think both solution will help you if helpful for you please marke as helpful or like.
If we are using cascading then no need to write again and again the like address for each order so we will write once and use multiple time. And that field will auto filled no need to fill manually . this is the work of cascading . May be this will clear yor doubts. Marke as helpful please .
Pranay Tiwari
Hi Nagaraj,
Cascade Variables is check box in Order Guide,it is used for pass the variable value from order guide variable to order guide item variable.
cascade is use when order guide have some common variable like Name ,Address ,Contact number  for every item this variable are common so we make those variable in order guide variable(Name ,Address ,Contact number) and fill once and this value will populate in over order guide item automatically.
Mark correct or helpful if it helps you.
Warm Regards,
Pranay Tiwari
| www.DxSherpa.com | pranay.tiwari@dxsherpa.com |
