02-10-2025 06:51 AM
i have added the step to ask for approval but i am not getting any prompts for it from the flow.
how to fix this ?
Walk-Up Experience
02-11-2025 03:47 AM
Hello @chercm
See flow not attaching on catalog item can be various reason.
1) Flow is not activated.
2) Flow is not mapped to catalog item.
3) Flow trigger condition are not matched.
4) If we change or modify ootb workflow [Service Catalog Request] over Request [sc_request] as this set the approval over Request and on basis of this only OOTB BR [Start FlowDesigner Flow] is triggered which fire off the flow if associated with item.
Now in your case ootb workflow was missing and that is reason your flow was not getting attached to request we submit from portal.
Anybody, if you are reading this post answer check this thread.
Thanks & Regards
Viraj Hudlikar.
02-11-2025 04:03 AM
Hello @chercm -
OOTB Workflow Name = Service Catalog Request.
Thanks & Regards
Viraj Hudlikar.
02-10-2025 08:24 AM
02-10-2025 08:27 AM
02-10-2025 08:29 AM
But your Flow is in RITM so it should go to RITM only.
02-10-2025 08:42 AM
the issue is that it is not requesting for approval
02-10-2025 02:48 PM
@Dr Atul - LNG it seems that after the approval and request state is set to approved on the req then the approval will appear at the ritm . here is my flow .
