Displaying wrong choice on Process flow formatter
DevYadav
Hi Community, Good Day! I am stuck on an issue! I created a Process Flow Formatter for a custom table (x_table) and added 15 choices in the form of counting (one, two, three, four, up to fifteen). The Process Flow Formatter is visible, but the problem is: It is not showing the correct state on the Process Flow Formatter. That is weird. I have double-checked each choice to ensure it is active, the filter condition is applied, and the order is not duplicated. However, if I select the third choice, instead of displaying that choice on the Process Flow Formatter, it shows the fourth one. In short, it is displaying one choice ahead, which is incorrect. Thanks in advance!
Dushyant Siroh
Hi @DevYadav
Can you please check sys_choice records for custom table and verify the sequence its correct or wrong .
Dushyant
Hi @Dushyant Siroh
Would it be possible for you to provide screenshots with a simple use case for better understanding? I believe I have already checked every possible solution for this."
This will clear my concept!!!
Hi @DevYadav
Please check this screenshot , I thinks its will be helpful to you.
Dushyant
I just checked sequence is correct, now checking one more time everything from scratch, might be able to find any flaw or missing!!!
