02-10-2025 06:51 AM
i have added the step to ask for approval but i am not getting any prompts for it from the flow.
how to fix this ?
Walk-Up Experience
02-11-2025 03:47 AM
Hello @chercm
See flow not attaching on catalog item can be various reason.
1) Flow is not activated.
2) Flow is not mapped to catalog item.
3) Flow trigger condition are not matched.
4) If we change or modify ootb workflow [Service Catalog Request] over Request [sc_request] as this set the approval over Request and on basis of this only OOTB BR [Start FlowDesigner Flow] is triggered which fire off the flow if associated with item.
Now in your case ootb workflow was missing and that is reason your flow was not getting attached to request we submit from portal.
Anybody, if you are reading this post answer check this thread.
Thanks & Regards
Viraj Hudlikar.
02-11-2025 04:03 AM
Hello @chercm -
OOTB Workflow Name = Service Catalog Request.
Thanks & Regards
Viraj Hudlikar.
02-11-2025 01:29 AM
Hi @chercm
Everything looks good here. Now 2 things
- Create a new flow and test it, and don't add admin as an approver. Select any other user.
- Log a Now Support case.
02-10-2025 08:18 AM
02-10-2025 04:49 PM
As Atul mentioned, the approval is on the RITM record. It will not appear on the REQ.
Check on the RITM and see if the approver is listed.
02-10-2025 04:58 PM - edited 02-10-2025 05:03 PM
Hello @chercm
Are you sure flow is getting attached when item is submitted?
If no then see if flow mapped with required catalog item.? If done properly see is request getting auto approved as there some oot br which triggers flow workflow if request is approved if not flow never fire off.
If still issue i would recommend to check active context of flow and see what is runtime value pass for approval actions.
Thanks & Regards
Viraj Hudlikar.
02-10-2025 05:06 PM - edited 02-10-2025 05:07 PM
@Viraj Hudlikar how can i see that ? i can see all the catalog variables on the req and ritm but just that the auto approval piece is not working
