I have a requirement to create SLA records for closed RITM's that never had an SLA at the time of closure
Russell Abbott
I have a bunch of RITMs that were created and closed before we had RITM SLA's implemented. Is there a script that would go through each, generating the SLA record?
Here's a script i had partly put together from a similar reply here
var strQuery = 'active=false';
strQuery = strQuery + '^item=<item name>'; //catalog item name
gr.addEncodedQuery(strQuery);
while (gr.next()) {
var created = gr.sys_created_on;
var actual_end = gr.work_end;
var grSLA = new GlideRecord('task_sla');
grSLA.newRecord();
grSLA.task = gr.getUniqueValue();
grSLA.sla = '<sys_id>'; //sys ID of the SLA i'd like to run here
grSLA.schedule = '<sys_id>'; //sys ID of the schedule i'd like to run here
grSLA.start_time = created;
grSLA.end_time = actual_end;
grSLA.insert();
var task_sla = new GlideRecord('task_sla');
task_sla.get(grSLA.getUniqueValue());
SLACalculatorNG.calculateSLA(task_sla, false, task_sla.end_time);
This edited code worked for me part of the way. It set the start time at the correct time, i edited a line to get it to set the stop time correctly too, the stage of the SLA i forced to 'Complete' (although that text is in blue?).
The total calculated time however is up until the day the script runs and not when the RITM was completed
strQuery = strQuery + '^numberLIKERITM0028043'; //catalog item name
while (gr.next()) {
var actual_end = gr.closed_at;
grSLA.newRecord();
grSLA.sla = '89fb7bf21b05c550595042e58d4bcbd0'; //sys ID of the SLA i'd like to run here
grSLA.schedule = '01b228b81b162c10595042e58d4bcb61'; //sys ID of the schedule i'd like to run here
grSLA.stage = 'Completed';
var newSlaRecord = grSLA.insert();
new SLACalculatorNG().calculateSLA(newSlaRecord, false, grSLA.end_time);
Please give the proper back-end stage value in the script, I believe you gave the wrong one
I checked the back-end stage and it was a matter of lower case 'c' 🙂 Thank you!
Do we know why the calculation is not happening correctly? It is still calculating elapsed times from the created date/start time to the date i'm running the script, instead of 'stop time'
I removed the line below, and got the same result, so i don't think this line is even processing
new SLACalculatorNG().calculateSLA(newSlaRecord, true, grSLA.end_time);
I appreciate all your assistance!
Could you try this?
SLACalculatorNG.calculateSLA(newSlaRecord, false, grSLA.end_time);
It did not calculate still. The Actual elapsed time should be closer to 30-odd daysfind_real_file.png
