i need to set Role to false.
Rumanu
After termination, former employees  should:
Continue using their existing credentials and access the portal with limited access,
so, what i m thinking, to remove existing roles , user will still be active, and assign one alumni role to the same user,
but in sys_user_has_role table "active " field is dot walked from user table, when i update the active field in roles table, in user table also its getting updated. without deleting roles can we achieve?
Rumanu
we are using same portal and restricting the Record producers, via user criteria.
Hi @Rumanu
You cannot continue using the same user account. If the user is being terminated, their existing account must be deactivated.
Please create a new external user account with limited access using their personal ID.
**Continuing to use the same user account after termination would result in a compliance and security breach.
yea, i was also thinking same will discuss with my team once, and anyhow can we do inactive roles? as i mentioned its dot walk from user table, overriding also not possible.
