I want a business rule that copies work notes from a Problem Task to the associated Problem
kranthi2
Create a business rule that copies work notes from a Problem Task to the associated Problem whenever worknotes are added to the Problem Task.
Please help me out with the business rule.
Viraj Hudlikar
Tera Sage
Hello @kranthi2
In Advanced section tab under script field add below code:
    // Add your code here
    var problemRec = new GlideRecord('problem');
    problemRec.addQuery('sys_id', current.problem);
    problemRec.query();
    if (problemRec.next()) {
        problemRec.work_notes = current.work_notes.getJournalEntry(1);
        problemRec.update();
})(current, previous);
Thanks & Regards
Viraj Hudlikar.
Hi @Viraj Hudlikar
It works, Thanks.
@SreenadhV  -
Glad that it helped you.
You can also mark it as helpful 👍
