Importing bulk knowledge articles
Bhavani1995
how does using the CSV/XML process work with bulk knowledge import. Specifically if and when the article has images. The legacy system can export articles in CSV/XML format with required fields (title, body, metadata, valid to date). what is the process of it
16 REPLIES 16
Hi @Bhavani1995
Importing via XML or CSV is not feasible, as these formats do not support images or related content. It is recommended to proceed with importing via Word, as suggested.
Procedure
  1. Navigate to the All menu > Knowledge > Import Articles module.
  2. Select an appropriate knowledge base from the list.
  3. Organize your knowledge articles by category and import the articles by category. You can upload one or more articles at a time during import.
  4. Click the Import button.
Can we import 2000 articles the way you have mentioned
Hi @Bhavani1995
Yes, but you need to browse through them one by one, as shown in the screenshot.
Bhavani1995
what is the process of importing the xml/csv file
Hi @Bhavani1995
You can check the given  link mate.
