Importing bulk knowledge articles
Bhavani1995
how does using the CSV/XML process work with bulk knowledge import. Specifically if and when the article has images. The legacy system can export articles in CSV/XML format with required fields (title, body, metadata, valid to date). what is the process of it
16 REPLIES 16
I am not clear of importing the csv/xml, can you help me out how to import csv/xml process
Bhavani1995
What is the process of importing bulk kb articles  of csv/xml
VikMach
@Bhavani1995, are you saying you want to export existing KB articles from one instance and import the same into another instance?
Is this what the ask is?
Please clarify!
Vikas K
We have some xml files to be imported into the real time instance
We have some xml files to import to our instance
