In catalog item we have used multi row variable set (MRVS), while submitting the form in RITM MRVS is populating but in SCTASK it is not showing, i want to display the MRVS in SCTASK level
gm6
hi @gm
If you are using workflow/flow add the mrvs variable in
Murthy
13 REPLIES 13
gm6
I'm creating the task in DEV Portal which we use regularly for testing, but dont know why it is not reflecting the MRVS in SCTASK along with variables
hi @gm
Murthy
gm6
HI @Murthy Chintalapudi
It is working now, Thank you so much Grinning face with big eyes
Mohith Devatte
Tera Sage
hello @gm ,
you can try this script in a display Business rule on SC task table refer to @Suseela Peddisetty script in the below link it worked for me
https://community.servicenow.com/community?id=community_question&sys_id=46eb34d3db59e8504aa5d9d96896...
Hope this helps
Mark the answer correct if this helps you
