In portal i want to modify the color of My Ticket Surveys how to achieve the same?
kranthi2
In portal I want to modify the color of My Ticket Surveys how to achieve the same?
Please help me out how to configure the same and how to achieve it with out affecting for other SP portals which are available in the SNOW Instance.
@Ehab Pilloor
Could you please more clear on the point no.3 and point no,4 i am not getting exactly.
Dr Atul G- LNG
OOTB It is here
But your are customized Portal , so follow same path and your work done.
Hello @Dr Atul G- LNG
I have tried with your response it is working fine but it is changing for the remaining portals as well which is not expected.
Please help me out that i want this color should only for my portal not for all the SP portals in servicenow.
Hi @kranthi2
If you are using ootb widget in all portals then it will impact every where.
So Clone this widget n make changes.
