in Problem task the close_notes field label showing as canceled reason
Debasis Pati
@Ankur Bawiskar any idea on this?
There are no labels no dictionary over-rides for this
9 REPLIES 9
@Debasis Pati
if dictionary label is Canceled reason then it's understandable
But if not then any dictionary override or script doing?
No Ankur,
OOb action happening but there is no as such labels for this not sure from which script or from where?
OOB , I checked - its happening . Looking for the reason.
Chris Plunkett
Probably what you are seeing is a result of the 'Rename Closed fields on change' client script running
Laveena-Agarwal
Hi @Debasis Pati
I have found it 😊
The Canceled Reason is mapped to the "close_notes" field, but the label is being updated dynamically via the onChange client script "Rename Closed fields on change"
Look at the highlighted part below, when close_code is canceled, it is changing the label to "Canceled Reason".
Screenshot 2026-04-04 at 5.32.46 PM.pngScreenshot 2026-04-04 at 5.33.27 PM.png
