Incident - Resolution code
Ruchi19
Mega Contributor
We're planning to enhance the resolution code for our Incident management. I wanted to see what kind of resolution codes you're using so that it helps you better on Incident trending and resource utilization.
For ex: I am more thinking like hierarchical closure codes for us. I have come up something like this
  • Application/Software
      • defect raised
      • Existing Defect
      • Restart / Reboot
      • Configuration changes
      • new functionality / enhancement
Any thoughts / suggestions or samples to share what you do on your side?
Thanks again
mduluk
Giga Expert
I attached our layout, however I do 100% agree with rfedoruk.   If you do not have a level of accountability, and management is not actively reporting off the close codes, the hierarchical method can quickly generate bad data.
12 REPLIES 12
You can use Informational only or Training Opportunity as a cause code for incidents like these.
sarah44
Kilo Explorer
hello
We are currently looking at our SN implementation and this is something we are looking at
ie to add a "reason" when closing incidents, so we can run trend analysis to "spot problems"
To do this , did you make some config or did you have to add customisations
We are trying to avoid customisations, as this can impact release upgrades
thanks
sarah
OOB there's a closure code choice list.
