11-05-2019 07:25 AM
I am trying to add a blue bar info message under a field with a client script. I want the info message to be several lines. How can I do a line break on the info message to have the message show on multiple lines? I want it to look like the below but I have tried a few different options and it just puts in on the same line.
5 - Exceeds
4 - Meets
function onLoad() {
g_form.showFieldMsg("u_review", ("5 - Exceeds" + + "4 - Meets"));
callback(saveAndClose);
Request Management
11-05-2019 09:40 AM
I just put an alert to confirm.
You can comment out the alert line in your code.
11-05-2019 09:17 AM
11-05-2019 09:40 AM
11-05-2019 12:46 PM
Thank you Prateek I was able to get his to work. I appreciate your help and have marked this correct.
Russell
11-05-2019 07:43 AM
Check this out, might help
-Anurag
11-05-2019 08:17 AM
You can can have two showFieldMsg stataments
g_form.showFieldMsg("u_review", "5 - Exceeds");
g_form.showFieldMsg("u_review", "4 - Meets");
