Info MessageAt least one of flow, workflow or execution plan should be filled. Otherwise, when order is placed, then even on approving request, the stages of requested item won't be updated.
06-07-2022 11:25 PM
Hello Team,
Can anyone elaborate on this?
I have not filled up both workflow and execution plan as I am using BR to generate SCTasks based on a MRVS rows. Is it mandatory to fill in these?
Service Catalog
06-08-2022 04:57 AM
I have always used either workflow or flow for submitting catalog item.
Why not use workflow with run script to create those many sc_tasks?
06-08-2022 10:50 PM
Hello Ankur,
Thanks for the response.
We have ruled out the option of using workflow as our custom app required to use only BR.
If BR is used, can we use execution plan and suppress its actions?
