How to auto populate a record producer field based on reference field selection.
jmcm
I want to auto populate the field DESC with the description of the incident selected in field INC.
Once the incident has been selected, the description of the incident should auto fill.
How can this be achieved with a catalog client script to do a glide ajax to a script include?
All help is appreciated, thanks in advance!
11 REPLIES 11
Ujjawal Vishnoi
You can use the with callback as below in onchange client script on inc field change
var volume = g_form.getReference("inc", setCurrentValues);    //Replace inc with INC variable name
function setCurrentValues(inc) {
g_form.setValue("desc", inc.short_description);  //Replace desc with DESC variable name
Below is the screenshot of the screen.
Hope this helps
@jmcm
Please mark my response correct and helpful. If i am able to help you with your query and this can be removed from unresolved list.
@jmcm
Please mark my response correct and helpful. If I am able to help you with your query and this can be removed from unresolved list.
@jmcm
Please mark my response correct and helpful. If I am able to help you with your query and it can be moved to answered list and helpful for future readers.
