Input check at onSubmit /Implemented with Client Script
user_ms
Only one error message is displayed at onSubmit.
When I resolve one error, another error appears.
If there is an error in two items, I want to display the error messages for both items at the same time at onSubmit.
Please let me know if you know how.
@user_ms Here is the updated script, it will hold the form submission until the error is corrected.
function onSubmit() {
    g_form.clearMessages();
    var fieldArray = ['test1', 'test2'];
    var regex = /^[0-9]+$/;
	var errorCount= 0;
    for (var i = 0; i < fieldArray.length; i++) {
        if (!regex.test(g_form.getValue(fieldArray[i]))) {
            g_form.showFieldMsg(fieldArray[i], 'error!', 'error');
			errorCount++;
    if(errorCount==0){
		return true;
	else{
		return false;
@Sandeep Rajput
I was solved this way.
Thank you.
Harish Bainsla
hi
var errorMessages = [];
var item1 = gForm.getValue('item1');
if (!item1) {
errorMessages.push('Item 1 cannot be empty');
var item2 = gForm.getValue('item2');
if (!item2) {
errorMessages.push('Item 2 cannot be empty');
if (errorMessages.length > 0) {
gForm.addErrorMessage(errorMessages.join('\n'));
return false;
return true;
