integration with datadog
karan15
HI All ,
Am trying to integrate datadog with service now by following this article here >>>https://docs.datadoghq.com/integrations/servicenow/<<<
however it asks to upload the XML file to service now but when i tried , servicenow accepts only xls format
anyone else has successfully integrated datadog with snow ? and using it for inc creation etc ?
11 REPLIES 11
Hey Steve, did you fix this? Have the same issue now
Hi @Matt_watts23 -
Yes, I was able to fix it. Assuming you have everything set up in ServiceNow for the Datadog user, you'll need the Datadog admin to create a Datadog service account. That service account will likely need to have just Datadog Read Only role. Once I set the role, I was able to get things to work. Now I just have to figure out how to map everything so the ServiceNow incidents are correctly populated.
Eric Smith
Karan15, hello! Did you integrate the systems successfully? Must admit i have only one datadog interaction so reading Tony's answer was interesting. Hope one day will have the chance to try this particular approach. So far, we've used a connector (it's called zigiops) to integrate our snow and datadog instances. I think it might be interesting for you. Feel free to check it out.
Kalyani35
Hi @karan15
Were you able to complete this implementation for Datadog Integration? Would like to know more on it as we also plan to do it.
Hi @Kalyani35,
Can you help us or provide any document to setup integration between itsm servicenow and datadog.
Thanks in advance.
