Is it possible to base a reference qualifier for one reference field from another?
02-10-2026 06:27 AM
I’m trying to set a reference qualifier on the field change_request.u_business_line_approver.
The qualifier needs to use the value from change_request.cmdb_ci.assigned_to as the filter.
Has anyone implemented a similar qualifier, or can offer guidance on the best approach?
Thank you.
02-10-2026 06:29 AM
02-10-2026 06:46 AM
what's your actual requirement?
on CHG there is custom field referring to sys_user i.e. u_business_line_approver
Now you want to see only that user who is present in assigned_to of that CI on CHG form?
if yes then do this in advanced ref qualifier
javascript: 'sys_id=' + current.cmdb_ci.assigned_to;
02-10-2026 07:06 PM
Hope you are doing good.
