Is it possible to copy multi-row variable data to another MVRS?
Nagashree5
I have build a catalog item which has a MVRS and on submit of this it creates a RITM. Now, there is one more catalog where they select the closed RITM's and it has to copy the closed RITM MVRS values to form level MVRS.
I have some code that will copy the variables from the Requested Item to the form level, but I just noticed that it is not copying over the multi-row variable set information.  Multi Row Question Answer table [sc_multi_row_question_answer] has the values in it but I'm unable to copy them.
Has anyone come across this before? Is there an easy way to copy this data?
Thank you in Advance.
Arpita Patnaik
Hi @Nagashree5 I have the same requirement. Did you found the solution? can you share it?
Thanks in Advance
paulsunny
Any update on this . were you able to get this to work ?
Hi @paulsunny , I don't the script handy with me as this requirement was scraped from my client. However, you can try fetching the details from sc_multi_row_question_answer table.
