is my script include and client script is correct or not to get the user full name in description
srilekhac
var GetUserFullName = Class.create();
GetUserFullName.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    initialize: function() {
getFullName: function() {
        var user = gs.getUser();
        var fullname = user.getFirstName() + " " + user.getLastName();
        gs.log("Full name retrieved: " + fullname, "GetUserFullName");
        return fullname;
    type: 'GetUserFullName'
Bhimashankar H
Hi @srilekhac ,
yeah it seems correct, but why are you logging message in script include.
Remove the gs.log() line. It is already returning the full name of use to called functions.
Good script!
Bhimashankar H
If my response points you in the right directions, please consider marking it as 'Helpful' & 'Correct'. Thanks!
Ankur Bawiskar
@srilekhac
client callable script should not have initialize() method
This will work provided you are making the correct GlideAjax syntax from client side
1) if client script and script include are in different scope
-> make sure you call the script include with the API name
-> make Accessible from -> All Application Scope
2) if client script and script include are in same scope -> no worry
        var fullname = user.getFirstName + " " + user.getLastName();
        gs.info("Full name retrieved: " + fullname, "GetUserFullName");
        return fullname;
@srilekhac
Hope you are doing good.
Viraj Hudlikar
Tera Sage
Hello @srilekhac
You just provided script include which has logic proper but the script include if it need to called from Client Script the script include must be marked as client callable. Once that is done your client script will be able to call script include.
Also, in your code the concatenate logic you have use is also fine but there is another method you can utilize
var fullname = user.getDisplayName(); // this will get fullName of login user.
Thanks & Regards
Viraj Hudlikar.
