is my script include and client script is correct or not to get the user full name in description
srilekhac
var GetUserFullName = Class.create();
GetUserFullName.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    initialize: function() {
getFullName: function() {
        var user = gs.getUser();
        var fullname = user.getFirstName() + " " + user.getLastName();
        gs.log("Full name retrieved: " + fullname, "GetUserFullName");
        return fullname;
    type: 'GetUserFullName'
Hello @srilekhac
I believe you are doing great.
If my response helped, please mark it correct and close the thread so that it benefits future readers.
Thanks & Regards
Viraj Hudlikar
Laveena_A
Hi @srilekhac
You can skip this route to get the name from script include, alternatively follow this approach:-
In client script, you can simply use-
g_form.getFullName()
In Business Rule, use-
gs.getUser().getFullName();
Marked the solution as Helpful and Correct, if it works for you!
Laveena_A
Hi @srilekhac
You can utilize following methods to fetch the full name of current logged in user-
In Business Rule or server side scripting -
In client script -
