Is there a way to bring overview and findings field in servicenow sow workspace
‎07-24-2025 03:09 AM
Hello Everyone,
If i navigate to the view workbench ui action for resolved major incidents it takes me the workbench where i can see overview and findings field but if i see in service operation workspace i could not find those two fields is there a way i can add if yes how and if it is just hided by some small configuration it can be enabled to show on sow?
Please find the screenshots attached
@Ankur Bawiskar any idea?
Service Operations Workspace
‎07-24-2025 04:21 AM
I installed MI in my PDI and tried replicating what you're looking for. It seems it's not easily possible.
As I mentioned earlier, workbench' is not a direct form or UI page, so it's tightly integrated—especially when it comes to use any field , at any other place.
Better log a now support case for this.
Alternatively, you can create a page in the SOW using UI Builder, but please note that this will be a customization and may increase technical debt.
‎07-24-2025 04:58 AM
Seems you missed my below response.
‎07-24-2025 06:47 AM
Hey Ankur,
I haven't missed your reply i wonder is there anything intentionally they hided by some configuration on the ui for those two fields.
I tried to find out if any but couldn't i am very new to ui builder.
Debasis
‎07-24-2025 07:47 AM
If they have added that component then it makes sense for them to show it.
I don't think they are hiding it conditionally.
Did you check the record page in UI builder?
‎07-24-2025 08:02 AM
