Is there a way to disable business rule in transform script ?
Dinesh9
Giga Contributor
I want to disable some of the business rules while adding relationships data. I have used Run Business rule as false but it disabled all the business rule and i want some business to be enabled. So is there a way to disable some of the business rule in transform map.
Thaks,
Dinesh
Are you thinking to glide sys_script and make BR inactive?
Ankur Bawiskar
Hi Dinesh,
Hope you are doing good.
Let me know if that answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed.
