Is there a way to get SLA Breakdowns to work with past SLA data?
Dustin-Barre
I'm looking to use SLA Breakdowns on thousands of old records with older SLAs (all with metrics, etc., tracking assignment), but I can't figure out how to populate SLA Breakdowns with that old data. Is that even possible? Or do they only work with future SLAs?
AshishKM
Hi @Dustin-Barre ,
The OOTB SLA calculation works on based on configured scheduled and other record level conditions.
I don't see any option to break the completed SLA, but if you have updated SLA definitation then it will apply to new SLA instance.
-Thanks,
AshishKM
AshishKM
Hi @Dustin-Barre ,
-Thanks,
AshishKM
AndersBGS
Hi @Dustin-Barre ,
No, according to my knowledge their is not.
best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
