Options
07-17-2022 09:52 PM
There is a link on an interaction form called "Create Incident" .
Is there a way to identify all such incidents which are created from interactions?
Labels:
Incident Management
Options
07-17-2022 10:04 PM
Hi Smriti,
When Incident is created from Interaction 'Create Incident' link, Is there any configuration have done which updates Contact type/ Channel field on incident?
Or you can check the Parent field for the same.
Sagar Pagar
Options
07-25-2022 02:16 AM
Contact type will always be walk in
