Issue in Populating response Body in ticket Creation AP
Vamshi_ch123
Hello everyone,
I'm attempting to populate the response body with the ticket ID when a customer creates a ticket using the shared API. I've created a REST API script for this purpose, but I'm encountering an issue where I'm receiving a status code 200, but the response doesn't contain the ticket number or any accompanying message."
(function process( /*RESTAPIRequest*/ request, /*RESTAPIResponse*/ response) {
   this.status = '200';
   var respObj = {};
  var payload = request.body.data;
var caller_id = payload.callerid;
var environment = payload.Environment;
var category = payload.Category;
var priority = payload.Priority;
var short_description = payload.Summary;
var description = payload.description;
var id = payload.W_Ticket_ID;
    var gr = new GlideRecord("sn_customerservice_case");
    gr.initialize();
   gr.short_description = short_description;
    gr.priority = priority;
	gr.category = category;
	gr.environment = environment;
	gr.u_ticket_id = id;  gr.description = caller_id + "\n" + priority + "\n" + environment + "\n" + short_description + "\n" + description + "\n" + id + "\n" + product + "\n" + account;
    gr.insert();
        respObj.body = {
            "message": "Creation Success!",
            "detail": "Case " + gr.number + " created successfully"
})(request, response);
Hi @Vamshi_ch123
I tried the following code in my PDI and it is working fine (see the screen shot, please try this code for one more time.
    var respObj = {};
    gr.initialize();
    gr.insert();
    var case_number = gr.getValue('number') + '';
    var resp_data_obj = {
        message: "Creation Success!",
        detail: "Case " + case_number + " created successfully"
    return resp_data_obj;
Anvesh
9 REPLIES 9
AnveshKumar M
Tera Sage
Hi @Vamshi_ch123,
Try this,
   var respObj = {};
    gr.initialize();
    gr.insert();
var resp_data = {
      response.setBody(JSON.stringify(resp_data));
And at the API consumption end parse the response back to JSON.
Please mark my answer helpful and accept as solution if it helped you to fix your issue 👍✔️
Anvesh
Hi @AnveshKumar M ,
I tried but getting below error
    "error": {
        "message""Script Evaluation Exception",
        "detail""Cannot convert {\"message\":\"Creation Success!\",\"detail\":\"Case CS0070692 created successfully\"} to org.mozilla.javascript.ScriptableObject (sys_ws_operation.2abdedb087bb25907d5032e83cbb358a.operation_script; line 27)"
    "status""failure"
@Vamshi_ch123
Try the below code and see still you are getting an error, and check for the system logs if there is any error.
    var respObj = {};
    gr.initialize();
    gr.insert();
    try {
            detail: "Case" + case_number + " created successfully"
        var resp_body_string = JSON.stringify(resp_data_obj);
        response.setBody(resp_body_string);
    } catch (ex) {
		gs.info("JSON Parse error: " + ex.message);
Anvesh
Hi @AnveshKumar M ,
Tickets are getting inserted, but response message is blank and in logs I could see the below message.
JSON Parse error: Cannot convert {"message":"Creation Success!","detail":"CaseCS0070699 created successfully"} to org.mozilla.javascript.ScriptableObject (sys_ws_operation.2abdedb08.operation_script; line 31)
