Issue with popup glideDialog window
Deepthi13
Hi Team,
I am getting below error and please find the UI page HTML snippet please guide if there is anything i am missing.
SCRIPT: UI PAGE(HTML)
<?xml version="1.0" encoding="utf-8"?>
<j:jelly trim="false" xmlns:j="jelly:core" xmlns:g="glide">
<div style="padding:20px">
<!-- receive sys_id from UI Action -->
<input type="hidden" id="sysparam_sys_id" value="${RP.getParameterValue('sysparam_sys_id')}"/>
<h2>Conflict of Interest</h2>
<p>Do you have a conflict of Interest?</p>
<div style="margin-top:20px">
<button class="btn btn-primary" onclick="submitCOI('YES')">Yes</button>
<button class="btn btn-default" onclick="submitCOI('NO')">No</button>
</div>
</div>
<!-- client script wrapped in CDATA -->
function submitCOI(answer) {
var sysIdEl = document.getElementById('sysparam_sys_id');
var sysId = sysIdEl ? sysIdEl.value : '';
// close current dialog safely
try {
var dlg = window.top.GlideDialogWindow.get();
if (dlg) dlg.destroy();
} catch(e) {}
if (answer === 'YES') {
// open second dialog (details page)
var dlg2 = new GlideDialogWindow('review_coi_yes_details'); // second UI PAGE
dlg2.setTitle('COI Declaration');
dlg2.setWidth(600);
dlg2.setPreference('sysparam_sys_id', sysId); // pass along sys_id
dlg2.render();
// NO -> navigate back to record (classic nav)
var url = 'sn_bom_internal_investigation.do' + (sysId ? ('?sys_id=' + sysId) : '');
if (window.top.g_navigation) window.top.g_navigation.open(url);
else window.top.location.href = '/' + url;
</j:jelly>
@Deepthi13
check below links for help
Demonstration Of UI Pages | Making Incident Form in UI Page
UI pages
AnjaliK64227824
Hi Deepthi,
I think you are missing
<script> tag
<![CDATA[ ... ]]> wrapper
as
Any JavaScript must be wrapped inside <script> tags
And because Jelly is XML-based, it must be enclosed in CDATA
Kindly check that
Its_Sagnic
Giga Guru
Hi @Deepthi13 ,
Try the below Process once :
HTML :
<g:evaluate var="jvar_sys_id" expression="RP.getParameterValue('sysparam_sys_id')" />
<input type="hidden" id="sysparam_sys_id" value="${jvar_sys_id}""")/>>
</div>
</div>
</j:jelly>
Client Controller :
var dlg = GlideModal.get() || GlideDialogWindow.get();
if (dlg) {
dlg.destroy();
var dlg2 = new GlideModal('review_coi_yes_details');
dlg2.setWidth(600);
dlg2.render();
var url = 'sn_bom_internal_investigation.do?sys_id=' + sysId;
if (window.top.g_navigation) {
window.location.href = url;
Try the code mentioned above...
If the code is helpful for you please put a like on it...
