Issue with Record producer map to field
Anoja
After upgrade to vancouver I am facing issue with Map to field in record producer. I am trying to map service offering field but by default it is taking active field as shown in below screen shot.
Any help is appreciable
Thanks in advance
Anoja
Harsh_Deep
Hello @Anoja ,
It's not mapping correctly because you have used reference field that will return a sys_id.
So for that use field type checkbox only to map it correctly.
Mark Correct if this solves your issue and also mark 👍Helpful if you find my response worthy based on the impact.
