Issue with ServiceNow Micro-Certification Lab Instance and Virtual Task Board
aakashbelda
Hello ServiceNow Support Team,
I am currently working on the Micro-Certification – Welcome to ServiceNow (Zurich) course and facing the following issues:
- My lab instance has been terminated and I have 0 instances remaining. The "Request Lab Instance" button is disabled.
- In the Favorites section, "My Incidents" is missing or shows "No records found", so I cannot access the required records.
- Because of this, I am unable to complete Assessment Simulator – Task 4: Create a Visual Task Board (VTB) from a List.
I kindly request your assistance in restoring or providing a new lab instance and resolving the "My Incidents" issue so that I can complete the micro-certification.
Thank you for your support.
Kind regards,
Aakash
Dr Atul - LNG
Log a now learning case with team, @aakashbelda
Tanushree Maiti
Hi @aakashbelda
Once a lab instance is marked as Terminated - it can’t be restored. Any data or settings from that instance are permanently lost.
To continue, you’ll need to request a new lab instance and proceed with your course using the new one.
For other course where you have requested the lab instance and not started course - Release that lab instance  .
NOTE: Lab instances are limited to 2 running instances per student.
Refer: KB0012234 Simulators, Instances, and Labs FAQ
Tanushree Maiti
Hi @aakashbelda
If you are unable to find the courses where you requested lab instance,
Raise a case with Now Learning Support in Servicenow University. They will help you.
https://learning.servicenow.com/lxp/en/pages/now-learning-help-center?id=nl_kb_home
