Issue with the Business rule not working
Pooja Khatri
I have a requirement where a change request goes through 4 level of approvals , first from the ag approval , second from Configuration item AG approval  third from the Change Request.AG approval and fourth one from Change Request Approval.AG approval .
so if the requested by or assigned to is a member of any of the above mentioned 4 AG approval group it should show the state as "not required" for those members in all the 4 AG approval levels
the first two approval groups first from the ag approval , second from Configuration item AG approval  is managed by this part of code : (current.sysapproval.requested_by.sys_id == current.approver.sys_id || current.sysapproval.assigned_to.sys_id == current.approver.sys_id and it is working perfectly fine
How to manage the scenario where the requested by or assigned to is a member of the Change Request.AG or Change Request Approval.AG -- this code is not working
How can I fix the above mentioned highlighted issue .
Business rule :
The BR is writted on the sysapproval_approver table and its an after insert BR .
Script :
var usr= current.approver.sys_id;
var mbr =[];
var mbr2 =[];
var grp = new GlideRecord('sys_user_grmember');
grp.addQuery('group', '67598c756f6a6100800e9eff6f3ee4e5');//Change Request.AG
grp.addQuery('user', usr);
grp.query();
while(grp.next()){
   mbr.push('yes');
var grp2 = new GlideRecord('sys_user_grmember');
grp2.addQuery('group', 'f37d1d6adb57e050d407da75ca9619e7');//Change Request Approval.AG
grp2.addQuery('user', usr);
grp2.query();
while(grp2.next()){
   mbr2.push('yes');
if(current.sysapproval.requested_by.sys_id == current.approver.sys_id || current.sysapproval.assigned_to.sys_id == current.approver.sys_id && mbr =='' && mbr2 ==''){
current.state = 'not_required';
current.update();
9 REPLIES 9
Kieran Anson
Hi Pooja,
Why create a new community post when others have already provided support on your previous article and awaiting your reply?
Issue with the Business rule - ServiceNow Community
Hi @Kieran Anson - I have replied  on the post .
Karunakaran
Giga Guru
What was the result? was it going to the final loop and only not updating the state? or it was breaking in middle anywhere ?
@Karunakaran
Yes it was going in the final loop and not updating
@Pooja Khatri okay. Please do a gliderecord of current approval record and perform your update. hope this works.
