issues with IF branch and currency field in flow designer
Elena Spıru
Giga Guru
On my form I have a currency field ('Amount') and in the Flow Designer I added an IF branch. I have different scenarios such as:
 IF
(Amount) GREATER THAN or is 100000
(Amount) LESS THAN  150000
{do stuff}
ELSE IF
(Amount) GREATER THAN 500000
{do stuff}
The problem is that when logging the value from the currency field it is retrieved as e.g. 140.000,00. So my IF statement is returning FALSE even if it should retry TRUE. I've tried also with num(100000) but i get the same issue.
I can't script anything in the IF action so really not sure where to go from here.
Any ideas?
Thank you,
Elena
Elena Spıru
Giga Guru
Solution found! Found out that the IF statement converts the currency field into a string, so with fx->string->convert string to number solved the issue.
Ankur Bawiskar
@Elena Spıru
you can use flow variable logic
How to configure an if condition for 'is greater than' in Flow Designer?
I've tried, but type is decimal and it won't work in my case.
Viraj Hudlikar
Tera Sage
Hello @Elena Spıru
Did you tried to apply function on field value you are comparing with your constant values. See example below, In this example I have click on fx button in condition input field and then use Math->Absolute Value to compare or you can use which suits your requirement.
If my response has helped you, hit the helpful button, and if your concern is solved, do mark my response as correct.
Thanks & Regards
Viraj Hudlikar.
Exactly, I just discovered it and it worked like magic! I used the Convert String to Number and tested all scenarios -> All successful!
