ITSM question help
SnowDevOps
Giga Guru
Hello
I have these questions that i need help to clarify if it is correct or not. Thanks for your help
When creating a catalog, which field specifies who can edit, update, and delete catalogs, categories, and catalog items?
A. Manager
B. Contributors
C. Owner
D. Editors
My guess: A or D not sure
Where do you enable the Search as feature for an incident?****
A. incident.deflection system property
B. Incident Properties application
C. Related Search Results table configuration
D. Incident form design
My guess is C
Which of the following elements are automatically included in the name of the update set for items published via Catalog Builder? (Choose two.)
• A. catalog(s)
• B. item name
• C. variables
• D. item author
• E. Timestamp
My guess: B & E
From a data model perspective, which table is the base class for the configuration management database?
• A. Configuration Item [cmdb_ci]
• B. Asset [asset]
• C. Base Item [cmdb_base_item]
• D. Base Configuration Item [cmdb]
My Guess is D
Harish Bainsla
Hi @SnowDevOps
Correct Answers:
  1. C. Owner
  2. A. incident.deflection system property
  3. B. item name and E. Timestamp
  4. A. Configuration Item [cmdb_ci]
Hi @Harish Bainsla
Correct Answers are:
  1. A. Manager
  2. C. Related Search Results table configuration
  3. B. Item name and E. Timestamp
  4. D. Base Configuration Item [cmdb]
If this solution resolves your query, kindly mark it as the accepted solution and give it a thumbs up.
Best Regards,
Krushna Birla
Omkar Kumbhar
Hello @SnowDevOps ,
Please find the below answers
Ans:  Editors
2) Where do you enable the Search as feature for an incident?****
Ans: Incident form design
3) Which of the following elements are automatically included in the name of the update set for items published via Catalog Builder?
Ans: B& E
4) From a data model perspective, which table is the base class for the configuration management database?
Ans: cmdb
Omkar
Krushna R Birla
Hi @SnowDevOps
Correct Answers:
  1. A.Manager
Best Regards,
Krushna Birla
