ITSM question help
SnowDevOps
Giga Guru
Hello
I have these questions that i need help to clarify if it is correct or not. Thanks for your help
When creating a catalog, which field specifies who can edit, update, and delete catalogs, categories, and catalog items?
A. Manager
B. Contributors
C. Owner
D. Editors
My guess: A or D not sure
Where do you enable the Search as feature for an incident?****
A. incident.deflection system property
B. Incident Properties application
C. Related Search Results table configuration
D. Incident form design
My guess is C
Which of the following elements are automatically included in the name of the update set for items published via Catalog Builder? (Choose two.)
• A. catalog(s)
• B. item name
• C. variables
• D. item author
• E. Timestamp
My guess: B & E
From a data model perspective, which table is the base class for the configuration management database?
• A. Configuration Item [cmdb_ci]
• B. Asset [asset]
• C. Base Item [cmdb_base_item]
• D. Base Configuration Item [cmdb]
My Guess is D
Saturn
And - Managers
Saturn
