Kindly help me with below requirement
keval3
Hi Team,
I have below requirement.. there is one custom table call Ldoc in witch there are one field called Milestone with choice list type it is basically works like state field. basically I want to create new field called TAT where I can show the timing of Milestone changing time. please let me know how to do it. kindly find below screen snap for same.
I want to create that field because I want to create report where I will have to capture the Timing.
Thanks & Regards
KP
AndersBGS
Hi @keval3 ,
Based on your description and snip that you have provided, I would recommend you to go with metric definition. This will provide the information that you're looking for.
keval3
Hi  AndersBGS,
I have created metric and it works but i want ldoc no in my report witch was my custom table no I have created report on Matric table. I wanted to add below things in my report kindly let me know how to do it.
